Can I get some help with a problem with syncing for my Nexus S 4g Google Samsung phone using Android version 4.1.2?
A
AC Question
problem with syncing for nexus s 4g google samsung phone using android version 4.1.2
Specifically "sign in error for cindy (myself) It asks me to retype a password, when I attempt to type password, another pop-up window comes up and says "unfortunately google search has stopped" It allows me to select 'report' or 'ok'. When report is selected, it goes to password but will not allow me to type in password.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,582
4,725
113
Re: problem with syncing for nexus s 4g google samsung phone using android version 4.1.2
Welcome to Android Central! Make sure your Google app is up to date. Open the Google Play Store, search for the Google app, and see if it has an Update button.
