Samsung Note 4 Android 5.1.1 Gear Fit Manager
Ken Clements
21
After upgrading to Android 5.1.1 on the Samsung Note 4 this morning... Gear Fit Manager fails to work.. after uninstalling and attempting to re-install App, notified that the Gear Fit Manager is no longer supported by the Note 4.
After contacting Samsung Support, i was notified that this is a known issue which they are working on... see thread below.
Mark
I apologise for any inconvenience. We already raise this concern to our developer and currently working on it.
14:03:46
OK, so this is a "known" issue?
14:04:15
Mark
We are aware of the concern and you may wait for the next patch of the update.
14:05:13
OK. THanks.
Issue has now been fixed. Go to the download page for the Gear Fit manager on the Samsung site from your device and download the Gear Fit manager... all working well.
r3dpuk3
