Why won't my Alcatel One Touch Fierce 2 detect Wifi Network suddenly?
QualityThomas
9
I've been having this problem days now and it's starting to bug me. It's not just to my wifi network it's to all. When the Wifi Notification has been detected, I tap and it shows nothing. It's only happening to the phone not effecting anything else. Could anyone please tell me a way to fix it. Thanks you beforehand.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,362
245
63
Welcome to Android Central. :)
First, try a Cache Partition wipe.
Tell us if still no go.
QualityThomas
9
It seems like the "Partition Wipe" isn't improving my problem. The phone won't scan or detect any wifi. Its been a couple weeks since this started and it's starting to bug me.
Javier P
Ambassador
Feb 21, 2014
19,480
3
Which way are you switching WiFi on & off? Quick settings panel or settings - WiFi? Any difference using one or the other? Check in settings - WiFi - advanced which frequency band is selected (select automatic).
QualityThomas
9
It seems like it's effecting everyone that's in the plan I'm in. I've tried several things like turning the WiFi on & off, I rebooted the cell phone several times, and it seems like nothing making the situation better. Sometimes when the WiFi notification detects networks I tap it and it shows no networks that's being detected. I've tried scanning but nothing happens. Is there any other ways to fix this problem?
" Check in settings - WiFi - advanced which frequency band is selected (select automatic)."
It doesn't have that option to select the frequency band.
SandiR
