Sony xperia Z2 help
meanman1967
4
Hi i have the above phone and i am having difficulties getting it to work on my WIFI, it will connect and it will work for a few days but then i get an explanation mark next to the wifi icon and it wont go online although it does say it is connected in wifi settings, i have several other phones in the house and other wifi devices and none of them have any problems at all, any help would be gratefully appreciated thank you.
meanman1967
4
Hi and thank you for your help, i have found this is a common problem with this phone i have just been poking around in my Virgin Media Super Hub settings and i found one for Guest wifi, i have set this up with a different ssid and different password, the phone has now connect fine and i hope this will fix it, thank you again for your help.
