How do I transfer an app to another device using an SD card?
A
AC Question
I have an sd card that I put a game on and I though that when you save it on the card you can move it anywhere if it's on the card but when I tried that it didn't work. I can't download it again on my other device because the game was removed for some reason from Google Play. If you have other ways to move it then thats good too. Thank you.
VidJunky
5,615
410
83
Only a portion of the game is saved on the SD you need to down load the game to whatever device to use it on another device. Also game saves won't transfer. If you'd like the game on other compatible devices Google the games apk and install it from your device's download folder. You'll have to accept install from outside sources.
smokedog87
