Heimdall and OS X 10.11 El Capitan ? Do they work together?
A
AC Question
I cannot install Heimdall 1.4.0 on my MBA with 10.11. The two are incompatible. Anyone else have this problem? Is there a fix?
ieatcalcium
5
I'm having the same issue as well. It doesn't install at all. The dev(s) haven't come out about any update for it either. Might just want to go to the library or something and create a bootable USB or something to use this guy.
Hate how every single mac update breaks applications.
akbarramadhani12
