Re: how to set up calender reminders samsung 4G lte
Welcome to Android Central! Which phone exactly? 4G LTE isn't a model name--it just means it has LTE capability.
Usually, if you select an event in the Calendar app and edit it, you can find an "Add Notification" or "Add Reminder" option there. Or you can go to Google Calendar on the web, edit the event, and choose the Reminder option there to send you an email.
