Accidentally uninstalled Kids Mode! How can I get it back?
VicaleaM
I accidentally uninstalled the store from Kids Mode. Now Kid's Mode app is gone. I hope somebody has some serious skills and can help me get this back. My sanity relies on you!!
Re: Accidentally uninstalled Kids Mode!
Welcome to Android Central! Moved to the General Help forum. Which device do you have? What do you mean when you say you uninstalled the store from Kids Mode?
I assume you have a Samsung device. Go to the App Manager. Is Kids Mode there? If not, open the Galaxy Apps Store, and search for Kids Mode. Can you install it there?
Hi! I have the S5...guess that was important info I could have included in my question!! I was going through and uninstalling space wasting apps. With kids mode, one of the apps within it is a store that kids can look for more games to download into the mode. When I accidentally uninstalled the store, it deleted the whole thing. When I look in app manager, it is listed in all. When I select it, it does not give me the option to reinstall. It is also nowhere in the Google store. It was a preloaded app.
Don't look in the Google Play Store--look in the Galaxy Apps Store, which is Samsung's app store. It should be in your App Drawer.
Go to settings where you add widgets you will see the kids mode widget pin it to home screen click on app then follow install
justinpoland05
