Re: what is soluation of unfortunately measure has stopped
Welcome to Android Central! Unfortunately, Measure appears to be malware, and is often associated with Monkey Test and some other malicious apps. I haven't found a clear solution on the web for this yet. I encourage you to continue doing some research on the web--look for "Measure Monkey Test malware."
