A
AC Question
Google Map v9.16.2 zoom problem when direction is ON
Set up a direction to some where. Then I wan to zoom-out for a better over view. I could do that very easily a few months ago. Now after upgrading google map to v9.16.2, it getting harder to do that. Each time when I zoom out, the map will re-store to previous scale. I have to try many time before the zoom-out stay. I am wondering whether it is a bug, or there is another trick to keep zoom stay. I have tried both two-finger zoom-out and double-tap zoom-out. Got the same result.
