Why do apps keep on installing themselves but NOT from Googleplay?
  • Start date Start date
A
AC Question
Apps keep on installing themselves but NOT from Googleplay.
The installation from unknown sources is unchecked and I don't know what's going on. I have tried installing security apps such as AVG security and Avast, but they say that the apps are safe. The apps are not from Google play, although there are apps with the same name on Google play. There has also been writing that I think was Chinese but am unsure that appears some times when I turn on my phone. this doesn't happen all the time, but the only way to get rid of that seems to be by taking out the battery, and the first time that this happened, it was open for a while and it showed what could be seen through the front camera. if anyone knows what is going on that would be very helpful, thank you.
slackingfred
