I started phone in Safe Mode but can´t find this virus so I can delete it. Then downloaded AVAST but can´t make it to run in Safe Mode. Would it help to reset phone to factory Settings? Please help..
With malware like that, it's usually best to do a factory reset. After finishing the Setup Wizard, go immediately to the Play Store and prevent any app from automatically installing. Now see if the malware is still there.
