Android Settings won't open its says launcher 3 stopped working after Factory reset, what can I do?
A
AC Question
Android Setting wont open its says launcher 3 stopped working after Factory reset
I think Android assistant app accidentally deleted important file then i cant find android setting so i tried factory setting but after that i still cant find android setting on home when i tried clicking the one on slides it just says launcher 3 has stop working now i cant set up my wifi or use anything HELP
the tall guy
Q&A Team
Sep 23, 2013
7,210
Re: Android Setting wont open its says launcher 3 stopped working after Factory reset
Try uninstalling action launcher 3 - this should bring you back to your stock launcher. Once you've tried that let us know if you still need help.
szcad
