Why aren't my texts sending?
A
AC Question
I'm on net10 and my android will not send my text messages or let me receive any, along with calls. Can anyone help? It alerted me that my SD card is removed but that's impossible because my battery and SD card aren't manually accessible when back is removed.
Javier P
Ambassador
Feb 21, 2014
19,480
3
Hi, welcome to the forums! That could be a problem with your SIM card or the carrier settings. I think you should contact your network provider for assistance. Can you check if your SIM card works fine in a different phone?
akbarramadhani12
