Results 1 to 13 of 13
    moviemogul's Avatar
    Posts
    Global Posts
    2,006 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I need to be able to read PDF's from E-Mails...
    When I receive an e-mail, and it has a PDF attachment, I click on "read". It says "Fetching Attachment", then says "Cannot Be Read"
    What can I do to make this work?
  2. #2
    STC09's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    which app are you using? I use Documents To Go, which seems to work quite well.
  3. #3
    Dapke36's Avatar
    Posts
    Global Posts
    619 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by STC09 View Post
    Yes, this program works great. Keep in mind, though, you cannot save those PDF'svin the free version.
  4. #4
    DeeMat's Avatar
    Posts
    Global Posts
    282 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    +1 to Docs To Go
  5. #5
    johnolesen's Avatar
    Posts
    Global Posts
    108 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    + 2 on Docs To Go...hell, if you use the features alot..15 bucks for the full version ain't bad
    moviemogul's Avatar
    Posts
    Global Posts
    2,006 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I don't have an app yet. Will the free DTG do PDF's in emails?
  7. #7
    Argodabar's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock GB
    Default
    I actually have that same problem. And I'm using the paid version of Documents to Go
  8. #8
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have never had that issue with the paid version of Docs2Go, but try searching the market for "PDF Viewers". There are several free versions available.
    moviemogul's Avatar
    Posts
    Global Posts
    2,006 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Ok, I just bought Docs To Go (love the 24hr refund...lol)
    Now, my PDF's say, "Fetching Attachment" and then "Connection Error"
    Ideas?
  10. Thread Author  Thread Author    #10
    moviemogul's Avatar
    Posts
    Global Posts
    2,006 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    actually... I'm getting a connection error from all new e-mails at the moment...hmm..gotta test this out
  11. #11
    Zorro1's Avatar
    Posts
    Global Posts
    1,056 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I can't save attachments WITH the full version of DTG. Well, I haven't tried pdf's, but I can't save Excel or Word files attached.
  12. #12
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Are you guys that are having problems using the built in messaging app? To initiate the save or opening of PDF attachments? I'm using TouchDown (I realize that's not an option if you're not syncing with an Exchange server) and I never have issues opening attachments. So maybe it's not the viewer, but instead the mail app.
  13. #13
    Zorro1's Avatar
    Posts
    Global Posts
    1,056 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Mine came in thru Gmail, was trying to get some docs on the Droid quickly without syncing.
