Results 1 to 3 of 3
    AgentofWrath13's Avatar
    Posts
    ROM
    CM7-RC2
    Default Cleaning Up The Micro SD Card?
    I'm a bit of a neat freak and recently looked at my micro SD card and all the files drive me crazy. How do I know what is okay to delete and is there any way that maybe I can hide them from my view?
  2. #2
    NickA's Avatar
    Posts
    Global Posts
    2,177 Global Posts
    ROM
    Stock
    Default
    I'm the same way. Do you have a bunch of files in the root of your card instead of sitting in a folder? Any important system files will not be on your SD card. That's where your music, pics, ringtones, data various apps use, etc. is stored.
    Thanked by:
  3. #3
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    Default
    A lot of apps create folders on the SD Card to store data and in most cases, the app may no longer be in use and the folder remains. i would suggest backing-up everything onto the computer and formating the SD Card. then you can go one by one and transfer things back onto the SD Card. This is a good time to keep photos/videos/music on your computer and move back the ones you think you'll be using.
    Mine is the same way and I plan on cleaning it soon.
    Thanked by:
