How to Manual/Force Update Samsung Galaxy S6 Verizon
MaxKittens
58
UPDATE SEPTEMBER 2017: USE THE LINK - bit.ly/upgradeandroid TO GET THE UPGRADE ASSISTANT AND FOLLOW THE STEPS IN THE PROGRAM.
Many people have been reporting the error where the Galaxy S6 from Verizon won't update. Usually it will give the error message "Software update is temporarily unavailable. Try again later." Screenshot_2015-11-29-14-34-16 (1).jpg This is shown using the G920V using T-Mobile Service. It will stay like this forever(at least in my case). To manually update your phone, connect it to your computer( windows preferably). Open up this pc, and double click CD DRIVE VERIZON MOBILE. Then at the bottom right of your screen there will be a series of prompts accept and install the drivers and software that it offers. If not using Verizon SIM remove the SIM until after updateRemove the sim BEFORE opening Upgrade Assistant When done press the start screen and search Verizon Wireless, press Verizon Wireless Software Upgrade Assistant(ar). Select the Galaxy S6 and press Upgrade SAMSUNG Galaxy S6. Then the upgrade proccess will begin. When it has finished it will restart and boot up with a alternate android logo. It will say "Erasing..." DO NOT FREAK OUT IT IS NOT ACTUALLY ERASING ANYTHING. Then it will come to a screen that says "Optimizing app # out of #". When this has finished it will boot up and the device will be updated. Enjoy!
Apostata
