A
AC Question
can my phone be salvaged?
Hi
Around 9 months ago I dropped my phone down the toilet and almost straight away got it back out. I tried taking it apart straight away and left it to dry for days. I even tried the rice but with no luck. I then put the phone back in its box and left it. This morning ive been having a clear out and came across said phone. On the off chance I switched it on and I heard a lot of beeps coming through. Possibly old emails and the 'home' keys at the bottom lit up. I tried swiping the screen as it to unlock it and I heard the noise that means its unlocked so the sensor on the screen appears to be working also It will also charge I know this because when I plug it in it makes the usual noise to indicate charging. Only one problem...there is no display on the screen which looks like the phone is when its switched off. I am taking it to get looked at later but just wondered if anybody knows from experience if its worth getting a new screen or if its a deeper problem?
Thanks in advance.
Hi
Thanks in advance.
