Results 1 to 11 of 11
    Default Help with rooting and installing CyanogenMod on htc aria
    Okay I KNOW there has been a lot of post on this but I'm new to rooting and custom roms and its just truely overwhelming with all this information and tutorials and different ways to do it that im having like a system overload. I've decided I want to root and install a CyanogenMod rom on my htc aria. So can someone with an htc aria and has successfully rooted and install a custom rom link me to a clear and concise tutorial where they learned how to do it? Also which version of CyanogenMod would you suggest? I want something super stable and I dont really care to adventure to the roms that have gingerbread unless its pretty much 100% stable and everything works.
  2. #2
    ls377's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    ROM
    Teamhacksung's ICS
    Default
    Here is the method I used with my Aria:
    Just stop before you start to install the ROM. Here's the Cyanogenmod wiki installation guide:
    Thanked by:
  3. #3
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    5,819 Global Posts
    ROM
    Homebrewed
    Default
    Note that if you've accepted the latest OTA there is no way to root :/
    Thanked by:
    ls377
  4. #4
    ls377's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    ROM
    Teamhacksung's ICS
    Default
    Quote Originally Posted by gbhil View Post
    I wasn't aware there was an OTA for the AT&T version recently. I know the Froyo update on the international one changed the HBOOT, but I didn't think that made it to the US version yet.
    OP: Can you check what number your HBOOT is? (Volume down+Power when powered off).
  5. #5
    AC Cowboy
    Posts
    Global Posts
    5,819 Global Posts
    ROM
    Homebrewed
    Default
    Quote Originally Posted by ls377 View Post
    You are just the man I'm looking for then.
    I have no Aria here, and have to rely on second and third hand info. I was under the impression that the last OTA upgraded Hboot to 1.0.2 and made it unrootable.
    If I'm wrong, I'm happy about it lol. If I am wrong, and it sounds like I am, feel like writing up a "how-to root the Aria for dummies" post? I'll get it stickeyed up.
    The Aria section needs a shepherd
  6. #6
    ls377's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    ROM
    Teamhacksung's ICS
    Default
    Unfortunately I don't have one anymore. I meant to write something up, but when I broke my LCD I decided it was time to switch. I'd be happy to write it up though.
    I'm not entirely sure about the OTA, since I was on Cyanogen since September, but I've only seen that issue on international versions. Maybe AT&T's meddling isn't all bad lol.
  7. #7
    AC Cowboy
    Posts
    Global Posts
    5,819 Global Posts
    ROM
    Homebrewed
    Default
    arrrghghhg.. lol.
    Thanks, but I won't ask you to field questions for a phone you no longer have. That's just not fair.
    If you know anyone from your Aria days who may be interested...point them my way
  8. #8
    ls377's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    ROM
    Teamhacksung's ICS
    Default
    Haha, I wish I still had one. I don't know of anyone who could do that (if anyone sees this, feel free to speak up). I'm willing to write something up and help out the best I can, and maybe someone will step up then.
    BTW, it seems the HBOOT in question is 1.02.000. That came from an international version. If anyone in the U.S has this HBOOT, please speak up.
    Default
    Okay thanks ls377 ill try it and report how everything went
  10. Thread Author  Thread Author    #10
    Default
    Okay Thanks ls377 I followed the steps and everything went smoothly. Now a problem i am facing is i cannot sync my google account. I go to settings> accounts and sync but i dont have the option to set up my google account. I digged online and saw that I should go to settings>applications>manage applications> and clear data on Google Apps but for some reason "Google Apps" is not listed anywhere can I get some help? Also my android market closes when I try to open it, is this due to me not having a google account?
    --- UPDATE-----
    Well I got tired of fighting with the rom to get the things working so i just flashed attn1 liberated 2.2 and couldnt me happier
  11. #11
    ls377's Avatar
    Posts
    Global Posts
    1,596 Global Posts
    ROM
    Teamhacksung's ICS
    Default
    There isn't a "Google Apps" app...Google apps include the Market, Gmail, and any of Google's apps.
    Try signing into Gmail, and then see if the Market works and the account syncs. If that doesn't work (or you've already done that), go to Manage Applications>Market and clear data.
