Keyboard layout file for external Logitech bluetooth keyboard and fixing letter g?
Bhadram Rao
keyboard layout file for extenal logitech bluetooth keyboard and fixing letter g.
1. external blue tooth logitech keyboard paired with lenovo a2010 on typing letter g it shows dialog complete action using with email and gmail instead typing letter g.
2. i tried to fix using adb pull system/usr/keylayout/ but not sure which one to change or modify there are many vendor...kl files existing over there.
3. How to find the vendor code for logitech k480 keyboard, i mean how to find the kl file for this keyboard.
4. what is the scan code i have to change or some solution to fix this problem.
fallingOutOfLoveWfithTech
