Calendar has stopped working after firmware upgrade
stevethepug
A couple of days after upgrading my Samsung Galaxy S to the latest firmware, I get:
"The application Calendar Storage (process.com.android.providers.calendar) has stopped unexpectedly. Please try again. Force Close"
I have tried restarting the phone and clearing the calendar data but that makes no difference.
Anyone got any ideas?
Thanks.
Did you try actually pulling out the battery, while the phone is running? If not, try that. Leave it out for a minute, replace it and restart. If the issue still existed and it was my phone, I'd try a factory reset.
Have you searched for this situation or posed this question in the Galaxy S forum? If not, take a look.
Did you clear just the calendar data, or also the calendar storage data? If not, try that. If that doesn't work, might be time for a reset.
Nazeer zaheen
