A
AC Question
I just bought a smartphone "Samsung Galaxy J2" (yup its late but i used all my android apps on laptop via bluestacks). Now i want some android advice before starting my android phone experience.
1. Where should i save my contacts? im not saving them on my sim (got both new duplicates so they have 0 contacts) or sd card or phone as they can get lost or damaged, i thought of saving them on my gmail account them and will sync them to the phone that case if in case i lose my sim or phone i will still have my contacts and will keep 0 contacts on phone memory and sim, am i doing it right??
2. Should i use an anti virus or not? many people say that there is no need for them and they just make mobile slow. i should only use Ccleaner. If i should which anti virus is the best and can i use it with Ccleaner will they conflict?... or should i use only anti virus which has a good cleaner (plz recommend which is the best one which is available free).
3. What necessary apps would you recommend for better phone life and management.
4. Can i attach my phone to my laptop for data transfer or i should never do it even bluetooth as it can get me viruses?
5. Should i avoid transferring data by bluetooth from other mobiles so it dosent get viruses?
