Is it possible to lock Location Services on?
A
AC Question
Location Services
Is it possible to lock location services on? Perhaps control the ability to turn it off or on with a passcode or something?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Re: Location Services
If you are in the usa, then e911 is always enabled and cannot be disabled.
For others, you can try to use the guest account option which would be more limited
Markizta
