A
AC Question
Chip and pin credit card is readable
So I have a credit card with a mag stripe and a chip. My card works perfectly fine at kiosks with swipe readers. However if I go to pay at at machine to exit a parking garage it is unreadable every time. Use card without chip and machine approves card just fine. Only thing I can think is those machines have rubber rollers that suck your card in when roller gets to chip part of card those rollers loose traction and throws off timing of card sliding over maghead? Anyone else have similar problem with chip cards?
