A
AC Question
First of all, I have read a lot of threads and tried many methods in fixing this problem. Here are the methods I tried: reformatting the SD card to default using my PC, reformatting the SD card to FAT32, using testdisk to recover partitions, and formatting it in the phone itself (all of these were suggested in threads). And although I'm getting more knowledgeable about SD cards, this problem still arises.
ok...now for the specifics. I am using a 64GB SanDisk Ultra PLUS microSDXC (UHS-1 and Class 10), and my LG Stylo is able to detect and format the card. However, when i power off and restart my phone, it will display "SD card is blank or has unsupported file system." When this happens, I'm unable to access my files (don't worry, i backed them up on my PC) and my phone is telling me i should format it (I have followed through on this, but it still arises if i power off my my phone), I have learned that if you remove the SD card and put it back in, then it will return back to normal. My problem is that this is really a hassle if i had to do this every time my phone powered off completely. The last resort for me is to avoid powering off completely, and everything will most likey be fine. However, I am asking this question right now to find out if there is a loophole in fixing this problem. Otherwise, I guess i just have to deal with this very annoying hassle. Please reply if you have some insight....(I am pretty inexperienced in technology)
