A
AC Question
It's not just a normal skip, it stops for less than a few seconds, then literally skips probably 30-60 seconds of the song, then a few seconds after that it goes again. Ads play fine though. I cleared cache, data, reinstalled, it's on local memory, tried it off and on wifi, with and without headphones, no battery saving apps, works on other devices on the same account, and battery does not come out. So as far as I found online, I did everything I could. This issue makes it unusable, as you could imagine, a song goes by in 20 seconds.
Anyone have any ideas?
