Hi all,
I'm looking to buy a new, budget smartphone and I've narrowed down my decision to the Nexus 5x or Oneplus 2.
I'm looking for a fast and smooth phone that runs high end games smoothly, and has no lag in apps (especially Chrome and YouTube) or on the homescreen. And I'm not that worried about NFC, camera quality or fast/wireless charging. I don't use those features much anyway.
On paper, the Oneplus 2 looks a lot better (4gb ram, etc), but I've heard that the OS and home button can be laggy at times. It is now 2016, so I'm not sure if any updates have solved this.
On the flipside is the Nexus 5x, which has less power, but seems to run very smoothly on Marshmallow, and has more regular support from Google.
So which is the better phone? Has the Oneplus 2 fixed its issues?
Thanks
Thanks
