A
AC Question
I cant disable the pin on my phone the directions i fallowed dose not have rhe options
It tells me to go to lock screen settings lock screen reenter the pin and then hit none. I did that but tells me I have to encrypt data off of external sd card I do not know what that means and I do not know how to
