Why do apps keep downloadng?
  • Start date Start date
A
AC Question
Apps keep downloadng
Hi I kept getting apps downloading on my tablet by themselves keep getting insane stars game ten drops game then a app called security and one called voice recorder the last 2 my anti virus always pops up saying they are suspicious but no matter how many times I delete them within a hour they are back on. I can't find them on the play store so they not from there. Can anyone help its becoming annoying now having to uninstall them. The only apps I have on are amazon kindle and anti virus
Re: Apps keep downloadng
Welcome to Android Central!
It sounds like you might have some kind of adware installed on your tablet. I personally would do a factory reset. Antivirus apps can get most of the files but a fresh wipe and reset will make sure its all gone.
