Trio stealth g5 7- frozen?
A
AC Question
Tried factory resetting my Trio because it has been acting slow and glitching lately. It has now been stuck on the same "erasing" little android robot for 24 hours now. What the heck? please help
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: Trio stealth g5 7- frozen
Force a reboot by holding the power button or removing the battery. See if that helps.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,516
4,656
113
Welcome to Android Central! I'd suspect either firmware or hardware defect. This is unfortunately more common with off-brand devices like yours. You could try contacting the manufacturer for support.
lucharmer
