Why do I have to keep redirecting certain apps to my 32g sd card?
A
AC Question
I added a 32 gb sd card to my Lenovo tablet so that I could direct most apps to that card & save built-in memory space. However, when I use certain apps such as Skype or Facebook, they seem to want to operate in main memory and I have to redirect them back to the sd card. Every time I check storage, certain apps need to be moved back...is this normal? Can I do anything to remedy this? Thanks.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Welcome to Android Central! Are you actually moving the apps to SD in the Settings>Apps menu, or are you instructing the apps to save data to the SD card (in the individual app settings)?
Finsrepair
