Re: my android M5 is not receiving calls
You can call out? Busy sounds like a provider issue. Have you attempted to call someone in your area with the same provider. I assume you're getting texts from those attempting to call, or how do you know calls aren't getting through and ringing busy in the other end? Is it all calls?
