Why won't my screen turn on?
A
AC Question
The screen won't come on
Well I checked all the connectors and they're fine,but the screen won't come on,I don't want to send it to get it fixed,what do I do?
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,388
254
83
Re: The screen won't come on
The screen itself may be bad.
the tall guy
Q&A Team
Sep 23, 2013
7,210
If you don't want to send it away to get fixed your kind of out of options I'm afraid. If you have tried everything and the screen won't come on then it sounds like a damaged phone. Have you tried changing the battery (if removable)
Chezsu
12
Buy an USB OTG cable to reproduce the screen to your TV/Monitor.
If your phone supports a dual OTG then you can plug a mouse in also and use the phone to retrieve files etc but apart from that you are screwed.
akbarramadhani12
