Where is my sim or sd card in my phone located?
A
AC Question
can't find sim or sd card in phone
want to know where sim or sd card is located on my phone.
ab304945
1,593
54
Re: can't find sim or sd card in phone
What phone do you have?
If it has a removable back cover, it should be behind it.
If not, look on the edge of the phone for a pin hole, if you find it that will be the Sim card tray.
Akshay
