SD card blank or has unsupported filesystem?
A
AC Question
Sd card blank or has unsupported filesystem
it just happened few hours before i was changing my display on instagram.
SD Card suddenly stopped working and start giving message ' sd card blank or has unsupported filesystem '
i connected sd card through card reader to computer as well but computer doesn't recognized it and nothing appears
any Help ?
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,365
110
63
Re: Sd card blank or has unsupported filesystem
Welcome to the forums. Have you tried reformatting the card?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Before you format anything, if you have files on it that you need, try PhotoRec (instructions at PhotoRec Step By Step). PhotoRec doesn't look at the filesystem, so if it's just the filesystem that's damaged, it should be able to recover most of the files on the card.
dumpsterrentals37
