Re: What is push messaging and how do I use it or what is it used for
Welcome to Android Central! Are you seeing that in an app's settings? Push messaging allows an app to show you a notification when you're not actively using that app in the foreground (e.g., getting an SMS notification when you're using the browser). This is in contrast to in-app messaging, which only works when you're actively using the app in the foreground.
