Why does my Kyocera Hydro Wave lockup on all screens after Android Update?
A
AC Question
My Kyocera hydro wave locks up in all screens and resets to same problem. Multiple 20 second holds of the power button simply reset it to same problem state. I had my phone fail yesterday so I bought another brand new one that does exactly same thing after an update was forced to install(metro pcs does this). I'm very frustrated and want to smash it into little pieces
ab304945
1,593
54
Update is probably bad.
Boot into recovery and format the cache and see if it helps.
If not do a factory reset, and don't let it update.
axool
