A
AC Question
Hey guys. I've been planning to do a factory reset on my phone as I suspect it might've gotten infected with malware. It hasn't shown any terribly out of the ordinary behaviors or clear indicators of infection - virus scans from a couple of reputable apps like Malwarebytes or Avast haven't detected anything as well - but I'd still like to take the safe route and be extra sure. I have a couple questions about this process though that I would like to ask you guys:
I've heard that factory resetting is the right method to be pretty much 100% sure anything malicious is gotten rid of on your phone (though it means all personal files on the phone will be deleted). I've also gotten the recommendation to check out certain apps on the google play store that can detect whether your phone has been rooted or not (I guess if it was, then something could potentially survive the reset).
So I wanted to ask you guys, are these pieces of information correct? Are these the correct steps in order to get a phone malware-free, and are such apps that check if you're rooted safe to use? Are there perhaps any other necessary steps to get my phone clean that I'm missing?
Also, how would one normally handle a google-account that's associated with one's phone? I guess deauthorizing any other devices and changing the password would be the most crucial steps. Are there other big dangers one should be aware of? For example, can the google account itself become infected in some way, so that it would re-infect my phone once I logged back in after the reset?
Thanks everybody, I'd greatly appreciate any advice!
