I'm thinking of taking that major step to change OS's. I'm a current WebOS user and for the most part love it. My biggest issues is that I don't have signal a large part of the time where I live and work (very rural) and...when your phone depends on signal to access the "web" part of WebOS you're kind of out of luck. So...
I'm thinking of switching to Android but have some major questions.
The phones seems to have 8 Gigs of internal. If you add on through expansion SD is the information aggregated into "all memory"? I had a BB for a short time and you had to choose which memory you were selecting from (music, documents, etc). It was a "seperate" memory. which was a real pain.
I also really like the multi-tasking option on WebOS. Does Android allow anything similar?
Also, should I wait for the newer Android phone (thunderbolt) as a replacement to my Palm PRe plus or is the Doird X an acceptable option?
THanks for any opinion.
