I have a Kyocera Model number is C6745 in I have bought a wireless seflie stick that you have to connect to the headset in I have read the direction that you all have been putting up,I have switched my volume key to capture in it still dosent work I have downloaded camera 360 in everything in did the same thing to that if you can give me some more clearier directions i think i can get my wireless selfie stick too work,also i have a bluetooth that goes around your neck but i dont that have anything to do with why my selfie stick dont work because i will turn that off. Everytime I press my button to take a picture it won't work buut when i press my volume up in doown button it will take a picture. Can you please help please
