1. iggyb_hube's Avatar
    I have a HTC Wildfire and have downloaded and installed Better Keyoard. I went through the initial set up. The problem is that it is not been called when I do any typing i.e. SMS, Email, Notes etc.
    What could be wrong and what may I have omitted?
    03-06-2011 01:31 PM
  2. crump84's Avatar
    Did you go to Settings > Language Keyboard and check your keyboard?
    03-06-2011 02:29 PM
  3. iggyb_hube's Avatar
    Thanks. Got sorted out. However at one stage I got a CPU warning with BK using 51% CPU. I have since disabled it again and reverted to the standard keyoard. Is there any reason why BK would use such high CPU?
    03-09-2011 10:21 AM
  4. Vietnam720's Avatar
    I have no affiliation with AnySoftKeyboard. Just recommending to u if Better Keyboard's problem persist/repeat again.
    03-14-2011 07:25 AM
