No confirm window nor prompt with JS androdi studios
Hello I have been doing apps for 6 months now but I have never done it on android, so I wanted to convert an old app of mine to an android app. The app was an HTML app, so I downloaded this file to make it work: https://github.com/slymax/webview . Every thing works fine exept that when you push a button it is suppose to pop up a confirm window, but it does not come up. Do anyone of you guys know what the problem is?
BTW when I published the app the Icon do not show up, it´s there when you download on the app store, but on the desktop of the phone it is just a standard android icon.
you can find the app here:
https://play.google.com/store/apps/details?id=com.piffen.remo
