A
AC Question
MXQ Pro Quick Play can't write to external USB HHD. Lollipop 5.1
Box is working great expect for external drives.
I have tried a 2TB USB HHD and a 32GB Stick. Both are seen, can mount and can be looed at with file manager software.
The problem is when I try to reference either item as a storage device for downloads (torrents) I get a message say either not accessible or not writable depending of app used.
I have not rooted the box (yet).
What do I need to do?
Thanks in advance,
Thanks in advance,
