I am hoping someone can clear this up for me. I know that normally, if you are using encryption and you want to remove it, you have to do a factory reset. However, this is for stock roms with the stock recovery.
I have read that if you are rooted, running a custom rom, and have a custom recovery that in order to remove the encryption, you have to use fastboot via ADB to flash a stock recovery image. So you basically revert back to stock. Is that correct?
If I do this, can I just flash another custom rom via fastboot instead of having to flash a factory rom? I would think I could but everything I read says to flash the stock rom so I am concerned that there may be a reason for this.
Thanks in advance!
Thanks in advance!
