A
AC Question
Noroot Firewall blocking WIFI Hotspot/Tethering
So I have been using Noroot Firewall for a couple years and was recently poking around changing some of the app settings. Some time later I was trying to use my phone as a WIFI Hotspot for my laptop and it would no longer work (it worked previously with Noroot Firewall running). I stopped Noroot Firewall and then the Hotspot worked again.
Anybody know what apps/services I need to re-enable in Noroot Firewall to get this working again?
Thanks,
-Brad
Thanks,
-Brad
