Why am I unable to screen lock my LG Stylo?
A
AC Question
I cannot disable the screen lock on my LG Stylo
I set a screenlock..I do not need it but now I cannot disable it. The swipe and none feature are greyed out.
mstrblueskys
Q&A Team
Dec 21, 2011
979
Re: I cannot disable the screen lock on my LG Stylo
Are you using Android Pay or does your work require a password on your device? It could be that you have an app which requires you to have a lock screen set.
Kandice71
No its actually my boyfriends phone..he put the lock screen on and then decided it was too much of a hassle but now it wont disable.
