A
AC Question
Why does the Chinese tablet don't remember the wifi password?
I have tablet model: cw-hi8-super with android 4.4.4
My problem is that every time I restart it I need to re - insert the password. It doesn't remember the password while other devices do remember the password.
Any suggestion why does it happen? Tried to reset it to default and it doesn't work.
Another possible to fix it by any wifi manager which controls the wifi connections and password on it's own (I tried some which probably take the passwords from OS so they don't have any passwords)
Any suggestions?
Any suggestions?
