I work for a small business in the middle of nowhere. Zero hardline internet access, with no hopes of ever getting it.
There is Sprint 4G coverage, and we have two phones (Samsung S5) dedicated to Tethering (using pdanet USB connections), but we need to upgrade our network infrastructure.
We don't have much extra money for all of the data we use which is why we are using pdanet and an unlimited data plan.
To upgrade the network we need to implement a few different routers and switches now. The trick is getting the internet from the phones using pdanet to the first switch.
So far I can do it with one phone. In the following sequence.
S5 with pdanet > Windows 10 laptop using connection sharing > Router
I want to be able to connect both S5's to a computer using pdanet, balance the load, and use connection sharing to go to the first router.
Right now pdanet will only recognize one phone at a time though, I need it to recognize both.
Any suggestions are welcome.
Each phone is currently pulling 30M down and 10M up. Crazy right? I've been running speed test's forever and those are the numbers.
Thank you in advance.
