How do I remove junk files?
A
AC Question
remove junk file
automaticaly Downlod Adlut Apps And After 2 Minite Mobile Reboot
the tall guy
Q&A Team
Sep 23, 2013
7,210
Re: remove junk file
Hi, are you stuck in the boot stage or can you turn the phone on? are you able to uninstall the apps through settings > applications? have you looked in your download folder encase an apk. file has been installed? Failing that a factory reset should help out the phone (make sure you back your data up first as it'll be wiped)
