Hi All,
I would like to bring to your notice about an issue I'm facing and not quite sure if you all are aware of this issue.
After I restarted my samsung note3 it wouldn't start as usual, it usually boots up fast but this time it took a while to start and when it finally started all i could see was the notification bar.
The screen was blank(all I can see is the notification bar and black screen) and im not able to open setting using notification bar or anything from notification bar. It just display my battery meter the time network ba etc. also i can pull the notification bar down and see quick connect or s finder but cant use them.
I tried to get all my data using usb but it wouldn't connect as my device uses a pattern lock which is restricting to open my folders unless i unlock my device.
Is there a way we can get the data before factory reset the device.
Or can we remove the pattern lock using adb but again we will have to enable usb debugging which is not possible.
